Salta al contenuto principale
Samsung ML2510 Side Cooling Fan Replacement
Cosa ti serve
  1. Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: passo 1, immagine 1 di 3 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: passo 1, immagine 2 di 3 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: passo 1, immagine 3 di 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Side Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Side Cooling Fan Replacement: passo 3, immagine 1 di 3 Samsung ML2510 Side Cooling Fan Replacement: passo 3, immagine 2 di 3 Samsung ML2510 Side Cooling Fan Replacement: passo 3, immagine 3 di 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: passo 4, immagine 1 di 3 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: passo 4, immagine 2 di 3 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: passo 4, immagine 3 di 3
    • Locate the holes on the panel that are attached to the main body.
    • Remove the front panel by gently moving the holes from the pegs one by one.
  5. Samsung ML2510 Side Cooling Fan Replacement: passo 5, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Samsung ML2510 Side Cooling Fan Replacement: passo 6, immagine 1 di 3 Samsung ML2510 Side Cooling Fan Replacement: passo 6, immagine 2 di 3 Samsung ML2510 Side Cooling Fan Replacement: passo 6, immagine 3 di 3
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Samsung ML2510 Side Cooling Fan Replacement: passo 7, immagine 1 di 3 Samsung ML2510 Side Cooling Fan Replacement: passo 7, immagine 2 di 3 Samsung ML2510 Side Cooling Fan Replacement: passo 7, immagine 3 di 3
    • Lift the right side-panel up from the raised stops.
    • Gently rotate the panel as indicated in the picture to remove the panel entirely.
  8. Samsung ML2510 Side Cooling Fan Replacement: passo 8, immagine 1 di 1
    • Poke out the side fan from the inside of the printer.
  9. Samsung ML2510 Side Cooling Fan Replacement: passo 9, immagine 1 di 1
    • Unplug the fan's wires from the side circuit board.
    • Replace the fan and reassemble the printer using reverse procedures.
Conclusione
Altre 2 persone hanno completato questa guida.
bbaustin
Membro da: 10/12/11
268 Reputazione
6 Guide realizzate
Cal Poly, Team 17-18, Regan Fall 2011 Membro di Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,546
