Introduzione
You will be required to disassemble much of the printer and its casing. You will need to refer to the Removing Samsung ML2510 Back Panel repair guide.
Strumenti
Parti
Nessuna parte specificata.
Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
Remove front panel by gently moving the holes on the panel from the pegs attached to the main printer body, one at a time.
Remove the cable attached to the motor.
The entire panel can be removed from the rest of the printer.
Using a Phillips #2 screwdriver, remove the motor from the panel by removing the two, 1", Phillips, PH#2 screws.
Replace the motor and reassemble the printer following instructions in reverse order.
