Salta al contenuto principale
Samsung Level Box Mini Speakers Replacement
Cosa ti serve
  1. Samsung Level Box Mini Speakers Replacement, Battery: passo 1, immagine 1 di 2 Samsung Level Box Mini Speakers Replacement, Battery: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
  2. Samsung Level Box Mini Speakers Replacement: passo 2, immagine 1 di 1
    • Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
  3. Samsung Level Box Mini Speakers Replacement: passo 3, immagine 1 di 1
    • Using the plastic opening tool, remove the batteries from the device.
  4. Samsung Level Box Mini Speakers Replacement, Speakers: passo 4, immagine 1 di 2 Samsung Level Box Mini Speakers Replacement, Speakers: passo 4, immagine 2 di 2
    • Remove the speaker grill from the device.
  5. Samsung Level Box Mini Speakers Replacement: passo 5, immagine 1 di 1
    • Remove the six 2.5 mm Philips #2 screws on the front of the device surrounding the speakers using the Screwdriver PH2 Philips Head.
  6. Samsung Level Box Mini Speakers Replacement: passo 6, immagine 1 di 3 Samsung Level Box Mini Speakers Replacement: passo 6, immagine 2 di 3 Samsung Level Box Mini Speakers Replacement: passo 6, immagine 3 di 3
    • Remove the eight 1.6 mm Philips #1 screws from the sides, front, and back of the device using the Screwdriver J000 Philips Head.
  7. Samsung Level Box Mini Speakers Replacement: passo 7, immagine 1 di 2 Samsung Level Box Mini Speakers Replacement: passo 7, immagine 2 di 2
    • Gently tap the back of the device to remove the speakers.
  8. Samsung Level Box Mini Speakers Replacement: passo 8, immagine 1 di 1
    Anti-Static Wrist Strap
    $7.95
    Compra
  9. Samsung Level Box Mini Speakers Replacement: passo 9, immagine 1 di 1
    • To put the replacement speakers onto the device, use a soldering tool to solder the wires onto the new speakers.
Conclusione
Altre 6 persone hanno completato questa guida.
Amanda Hymer
Membro da: 02/16/17
657 Reputazione
2 Guide realizzate
USF Tampa, Team 1-4, Kass Spring 2017 Membro di USF Tampa, Team 1-4, Kass Spring 2017
USFT-KASS-S17S1G4
5 Membri
3 Guide realizzate
2 Commenti
Só tem esse video que mostra passo a passo como desmontar o Samsung Level Box Mini.
Obrigado por compartilhar amigo, espero que esse video ajude outras pessoas.
saulo_venancio - Replica
Samsung seviye kutusu mini ses gürültüsünü engelleyen hoparlörler, devreden çok yüksek perdeli bir ses alıyorum.
Alaybeyi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 32
Tutti i Tempi: 4,591
