Salta al contenuto principale
Samsung LN-T5265F T-Con Board Replacement
Cosa ti serve
  1. Samsung LN-T5265F T-Con Board Replacement, Stand: passo 1, immagine 1 di 1
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
    • Slide the stand out from the bottom of the TV.
  2. Samsung LN-T5265F T-Con Board Replacement, Rear Case: passo 3, immagine 1 di 2 Samsung LN-T5265F T-Con Board Replacement, Rear Case: passo 3, immagine 2 di 2
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
  3. Samsung LN-T5265F T-Con Board Replacement, T-Con Board: passo 4, immagine 1 di 2 Samsung LN-T5265F T-Con Board Replacement, T-Con Board: passo 4, immagine 2 di 2
    • The Timing Controller (T-Con) board is located at the top center behind a metal shield.
    • Remove four Phillips screws.
    • Tilt the metal shield towards the top of the TV and lift away.
  4. Samsung LN-T5265F T-Con Board Replacement: passo 5, immagine 1 di 1
    • Disconnect the two ribbon cables at the top by flipping up the retaining flaps and sliding the ribbons straight up towards the top of the TV.
  5. Samsung LN-T5265F T-Con Board Replacement: passo 6, immagine 1 di 1
    • Disconnect the bottom ribbon cable by depressing the two buttons on either side of the connector and sliding down towards the bottom of the TV.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 10,069
