Salta al contenuto principale
Samsung L100 camera lens replacement
Cosa ti serve
  1. Samsung L100 camera lens replacement, Removing Back Cover: passo 1, immagine 1 di 3 Samsung L100 camera lens replacement, Removing Back Cover: passo 1, immagine 2 di 3 Samsung L100 camera lens replacement, Removing Back Cover: passo 1, immagine 3 di 3
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Samsung L100 camera lens replacement: passo 2, immagine 1 di 2 Samsung L100 camera lens replacement: passo 2, immagine 2 di 2
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Samsung L100 camera lens replacement: passo 3, immagine 1 di 3 Samsung L100 camera lens replacement: passo 3, immagine 2 di 3 Samsung L100 camera lens replacement: passo 3, immagine 3 di 3
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Samsung L100 camera lens replacement: passo 4, immagine 1 di 1
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Samsung L100 camera lens replacement: passo 5, immagine 1 di 1
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  6. Samsung L100 camera lens replacement, Camera Lens: passo 6, immagine 1 di 1
    • Remove the front cover, it comes off easily.
    • Buttons might fall out when you remove the front cover.
  7. Samsung L100 camera lens replacement: passo 7, immagine 1 di 1
    • Remove green tape from ribbon.
  8. Samsung L100 camera lens replacement: passo 8, immagine 1 di 2 Samsung L100 camera lens replacement: passo 8, immagine 2 di 2
    • Remove four screws around lens.
  9. Samsung L100 camera lens replacement: passo 9, immagine 1 di 1
    • Use spudger to remove ribbon connecting the circuit board from lens.
  10. Samsung L100 camera lens replacement: passo 10, immagine 1 di 1
    • Remove lens from camera.
Conclusione
Altre 5 persone hanno completato questa guida.
Adriel
Membro da: 04/15/10
123 Reputazione
2 Guide realizzate
Cal Poly, Team 6-17, Maness Spring 2010 Membro di Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 9,979
