Salta al contenuto principale
Samsung Juke Camera/Speaker Replacement
Cosa ti serve
  1. Samsung Juke Camera/Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Press and hold down the button on the bottom side of the phone with your finger.
  2. Samsung Juke Camera/Speaker Replacement: passo 2, immagine 1 di 2 Samsung Juke Camera/Speaker Replacement: passo 2, immagine 2 di 2
    • While holding the button down, remove the back cover of the phone.
  3. Samsung Juke Camera/Speaker Replacement, Camera/Speaker: passo 3, immagine 1 di 1
    • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
  4. Samsung Juke Camera/Speaker Replacement: passo 4, immagine 1 di 1
    • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
  5. Samsung Juke Camera/Speaker Replacement: passo 5, immagine 1 di 3 Samsung Juke Camera/Speaker Replacement: passo 5, immagine 2 di 3 Samsung Juke Camera/Speaker Replacement: passo 5, immagine 3 di 3
    • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
    • Failure to open USB port cover at this stage may result in damaging the device.
  6. Samsung Juke Camera/Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
  7. Samsung Juke Camera/Speaker Replacement: passo 7, immagine 1 di 2 Samsung Juke Camera/Speaker Replacement: passo 7, immagine 2 di 2
    • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
    • Practice caution to prevent damage to the attaching ribbon.
  8. Samsung Juke Camera/Speaker Replacement: passo 8, immagine 1 di 2 Samsung Juke Camera/Speaker Replacement: passo 8, immagine 2 di 2
    • Use the iFixit opening tool to gently pry the camera/speaker off.
Conclusione
Cal Poly, Team 6-18, Maness Spring 2010 Membro di Cal Poly, Team 6-18, Maness Spring 2010
CPSU-MANESS-S10S6G18
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,514
