Salta al contenuto principale
Samsung Jack Rear Case Replacement
Cosa ti serve
  1. Samsung Jack Rear Case Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Rear Case Replacement: passo 2, immagine 1 di 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Rear Case Replacement, Rear Case: passo 3, immagine 1 di 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Rear Case Replacement: passo 4, immagine 1 di 3 Samsung Jack Rear Case Replacement: passo 4, immagine 2 di 3 Samsung Jack Rear Case Replacement: passo 4, immagine 3 di 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Rear Case Replacement: passo 5, immagine 1 di 1
    • Lift the rear case off of the phone.
Conclusione
Paul Piller
Membro da: 04/12/11
56 Reputazione
5 Guide realizzate
Cal Poly, Team 24-57, Amido Spring 2011 Membro di Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,155
