Salta al contenuto principale
Samsung Instinct Back Case Replacement
Cosa ti serve
  1. Samsung Instinct Back Case Replacement, Battery: passo 1, immagine 1 di 1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Back Case Replacement: passo 2, immagine 1 di 1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Back Case Replacement, Back Case: passo 3, immagine 1 di 1
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Back Case Replacement: passo 4, immagine 1 di 2 Samsung Instinct Back Case Replacement: passo 4, immagine 2 di 2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Back Case Replacement: passo 5, immagine 1 di 1
    • Lift the casing off of the phone.
Conclusione
Cal Poly, Team 3-13, Regan Fall 2011 Membro di Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 854
