Salta al contenuto principale
Samsung Impression Back Speaker Replacement
Cosa ti serve
  1. Samsung Impression Back Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
    Chiedi a FixBot
  2. Samsung Impression Back Speaker Replacement: passo 2, immagine 1 di 2 Samsung Impression Back Speaker Replacement: passo 2, immagine 2 di 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
    Chiedi a FixBot
  3. Samsung Impression Back Speaker Replacement, Back Cover: passo 3, immagine 1 di 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    Chiedi a FixBot
  4. Samsung Impression Back Speaker Replacement: passo 4, immagine 1 di 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
    Chiedi a FixBot
  5. Samsung Impression Back Speaker Replacement, Back Speaker: passo 5, immagine 1 di 1
    • Carefully pry the back speaker upwards with a spudger.
    • The speaker is still connected to the circuit board by a wire and small piece of clear plastic.
    • Disconnect the speaker by lifting the clear plastic piece attached to the wire.
    Chiedi a FixBot
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 8-10, Regan Spring 2011 Membro di Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Membri
23 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 13
Ultimi 30 giorni: 67
Tutti i Tempi: 2,392
