Salta al contenuto principale
Samsung Impression Back Cover Replacement
Cosa ti serve
  1. Samsung Impression Back Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
  2. Samsung Impression Back Cover Replacement: passo 2, immagine 1 di 2 Samsung Impression Back Cover Replacement: passo 2, immagine 2 di 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
  3. Samsung Impression Back Cover Replacement, Back Cover: passo 3, immagine 1 di 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
  4. Samsung Impression Back Cover Replacement: passo 4, immagine 1 di 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
Conclusione
Cal Poly, Team 8-10, Regan Spring 2011 Membro di Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Membri
23 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,786
