Salta al contenuto principale
Introduzione
Demonstrates how to replace the front case of the camera through pictures and words. Replacement of the rear case requires disassembling battery housing and battery from front case.
  1. Samsung HMX-W300 Front Case Replacement, Remove wristband: passo 1, immagine 1 di 3 Samsung HMX-W300 Front Case Replacement, Remove wristband: passo 1, immagine 2 di 3 Samsung HMX-W300 Front Case Replacement, Remove wristband: passo 1, immagine 3 di 3
    • To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture.
  2. Samsung HMX-W300 Front Case Replacement, Front case screw removal: passo 2, immagine 1 di 2 Samsung HMX-W300 Front Case Replacement, Front case screw removal: passo 2, immagine 2 di 2
    • Remove all four Hex screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 Front Case Replacement, Remove HDMI screw: passo 3, immagine 1 di 3 Samsung HMX-W300 Front Case Replacement, Remove HDMI screw: passo 3, immagine 2 di 3 Samsung HMX-W300 Front Case Replacement, Remove HDMI screw: passo 3, immagine 3 di 3
    • To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00.
  4. Samsung HMX-W300 Front Case Replacement, Open front case.: passo 4, immagine 1 di 3 Samsung HMX-W300 Front Case Replacement, Open front case.: passo 4, immagine 2 di 3 Samsung HMX-W300 Front Case Replacement, Open front case.: passo 4, immagine 3 di 3
    • As shown in the picture, use the plastic opening tool on both sides on the device. Pry apart both parts.
    • Do not pry apart the device too hard. There is a wire that attaches the front case with the rear case.
  5. Samsung HMX-W300 Front Case Replacement, Unplug wire.: passo 5, immagine 1 di 3 Samsung HMX-W300 Front Case Replacement, Unplug wire.: passo 5, immagine 2 di 3 Samsung HMX-W300 Front Case Replacement, Unplug wire.: passo 5, immagine 3 di 3
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 Front Case Replacement, Battery screw removal: passo 6, immagine 1 di 2 Samsung HMX-W300 Front Case Replacement, Battery screw removal: passo 6, immagine 2 di 2
    • To remove the battery housing, you must first use a Phillips size 00 to remove the 4 screws.
  7. Samsung HMX-W300 Front Case Replacement, Battery housing removal: passo 7, immagine 1 di 1
    • Use the plastic opening tool to pry the battery housing open.
  8. Samsung HMX-W300 Front Case Replacement, Remove battery: passo 8, immagine 1 di 3 Samsung HMX-W300 Front Case Replacement, Remove battery: passo 8, immagine 2 di 3 Samsung HMX-W300 Front Case Replacement, Remove battery: passo 8, immagine 3 di 3
    • After removing the battery housing, take the battery out.
  9. Samsung HMX-W300 Front Case Replacement, Location of USB screws and wire slots.: passo 9, immagine 1 di 3 Samsung HMX-W300 Front Case Replacement, Location of USB screws and wire slots.: passo 9, immagine 2 di 3 Samsung HMX-W300 Front Case Replacement, Location of USB screws and wire slots.: passo 9, immagine 3 di 3
    • Here highlighted are the two Phillips size 00 and the slots where the wire is held.
  10. Samsung HMX-W300 Front Case Replacement, Remove wire.: passo 10, immagine 1 di 3 Samsung HMX-W300 Front Case Replacement, Remove wire.: passo 10, immagine 2 di 3 Samsung HMX-W300 Front Case Replacement, Remove wire.: passo 10, immagine 3 di 3
    • Use plastic opening tool to pry the plastic cover as shown
    • Use tweezers to remove the wire out of slots.
  11. Samsung HMX-W300 Front Case Replacement, Remove screw: passo 11, immagine 1 di 1
    • Remove both Phillips size 00 on USB port.
  12. Samsung HMX-W300 Front Case Replacement, Removal of USB: passo 12, immagine 1 di 2 Samsung HMX-W300 Front Case Replacement, Removal of USB: passo 12, immagine 2 di 2
    • Now push USB port inside the case to remove as shown.
  13. Samsung HMX-W300 Front Case Replacement, Replace front case: passo 13, immagine 1 di 1
    • Removal of the front case completed.
Conclusione
Robert
Membro da: 21/01/2015
966 Reputazione
8 Guide realizzate
USF Tampa, Team 9-2, Blackwell Winter 2015 Membro di USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 237
