Salta al contenuto principale
Introduzione
The battery is located inside the camera. To remove the battery, it will require uninstalling the battery housing. This can be done in a few steps found below.
  1. Samsung HMX-W300 Battery  Replacement, Remove wristband: passo 1, immagine 1 di 3 Samsung HMX-W300 Battery  Replacement, Remove wristband: passo 1, immagine 2 di 3 Samsung HMX-W300 Battery  Replacement, Remove wristband: passo 1, immagine 3 di 3
    • To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture.
  2. Samsung HMX-W300 Battery  Replacement, Front case screw removal: passo 2, immagine 1 di 2 Samsung HMX-W300 Battery  Replacement, Front case screw removal: passo 2, immagine 2 di 2
    • Remove all four Hex screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 Battery  Replacement, Remove HDMI screw: passo 3, immagine 1 di 3 Samsung HMX-W300 Battery  Replacement, Remove HDMI screw: passo 3, immagine 2 di 3 Samsung HMX-W300 Battery  Replacement, Remove HDMI screw: passo 3, immagine 3 di 3
    • To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00.
  4. Samsung HMX-W300 Battery  Replacement, Open front case.: passo 4, immagine 1 di 3 Samsung HMX-W300 Battery  Replacement, Open front case.: passo 4, immagine 2 di 3 Samsung HMX-W300 Battery  Replacement, Open front case.: passo 4, immagine 3 di 3
    • As shown in the picture, use the plastic opening tool on both sides on the device. Pry apart both parts.
    • Do not pry apart the device too hard. There is a wire that attaches the front case with the rear case.
  5. Samsung HMX-W300 Battery  Replacement, Unplug wire.: passo 5, immagine 1 di 3 Samsung HMX-W300 Battery  Replacement, Unplug wire.: passo 5, immagine 2 di 3 Samsung HMX-W300 Battery  Replacement, Unplug wire.: passo 5, immagine 3 di 3
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 Battery  Replacement, Battery screw removal: passo 6, immagine 1 di 2 Samsung HMX-W300 Battery  Replacement, Battery screw removal: passo 6, immagine 2 di 2
    • To remove the battery housing, you must first use a Phillips size 00 to remove the 4 screws.
  7. Samsung HMX-W300 Battery  Replacement, Battery housing removal: passo 7, immagine 1 di 1
    • Use the plastic opening tool to pry the battery housing open.
  8. Samsung HMX-W300 Battery  Replacement, Remove battery: passo 8, immagine 1 di 3 Samsung HMX-W300 Battery  Replacement, Remove battery: passo 8, immagine 2 di 3 Samsung HMX-W300 Battery  Replacement, Remove battery: passo 8, immagine 3 di 3
    • After removing the battery housing, take the battery out.
Conclusione
Altre 6 persone hanno completato questa guida.
Robert
Membro da: 21/01/2015
966 Reputazione
8 Guide realizzate
USF Tampa, Team 9-2, Blackwell Winter 2015 Membro di USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Membri
16 Guide realizzate
2 Commenti
What type of battery is this? What part number should we use to order a replacement?
VanDemark - Replica
The type of battery should be printed on the case of the battery. Most likely it’s some type of lithium battery. The part number for the battery should be on the case as well. If you can’t find either of these on the battery case you can take the battery to a place that sales batteries and the personnel there should be able to tell you the type and part number for your battery.
Jarretti Reaves -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,886
