Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Use this guide to remove the outer casing of your device.
Parti
Nessuna parte specificata.
  1. Pull the release tab away from the battery. Slide the battery towards the release tab and then pull the battery away from the camcorder. Slide the battery towards the release tab and then pull the battery away from the camcorder.
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Rotate the camcorder so that the strap side is facing you. Locate and remove the three 4.5mm  Phillips #00 screws around the hand strap.
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Acquista ora
    Acquista ora
  4. Rotate the camcorder so that the battery slot is facing you. Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  5. Rotate the camcorder so you are looking at the bottom of the camcorder. Locate and remove the last three 4.5mm Phillips #00 screws.
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  6. With both hands, pull the side strap apart from the rest of the camcorder. With both hands, pull the side strap apart from the rest of the camcorder. With both hands, pull the side strap apart from the rest of the camcorder.
    • With both hands, pull the side strap apart from the rest of the camcorder.
Conclusione
Amir Harb
Membro da: 26/09/2017
697 Reputazione
6 Guide realizzate
USF Tampa, Team S13-G1, Boczar Fall 2017 Membro di USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 168
