Salta al contenuto principale
Samsung HD Pro Heatsink Replacement
Cosa ti serve
  1. Samsung HD Pro Heatsink Replacement, Casing: passo 1, immagine 1 di 1
    • Locate a small opening around the front panel of the camera.
  2. Samsung HD Pro Heatsink Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
  3. Samsung HD Pro Heatsink Replacement: passo 3, immagine 1 di 1
    • Remove both of the connecting wires from the motherboard.
    • Be careful to not bend headers or damage the wires.
  4. Samsung HD Pro Heatsink Replacement: passo 4, immagine 1 di 1
    • Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
  5. Samsung HD Pro Heatsink Replacement: passo 5, immagine 1 di 1
    • Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
  6. Samsung HD Pro Heatsink Replacement, Heatsink: passo 6, immagine 1 di 1
    • On inside of front casing, locate heatsink.
  7. Samsung HD Pro Heatsink Replacement: passo 7, immagine 1 di 1
    • Using careful force, push in the white tab and pry up heatsink with fingers.
  8. Samsung HD Pro Heatsink Replacement: passo 8, immagine 1 di 1
    • Check to make sure all wires are completely detached from the motherboard.
  9. Samsung HD Pro Heatsink Replacement: passo 9, immagine 1 di 1
    • Pull the circular circuit board away from the rest of the device, being careful not to bend any of the pins connecting the two.
  10. Samsung HD Pro Heatsink Replacement: passo 10, immagine 1 di 1
    • Locate the three white tabs holding the next circuit board inside the case.
  11. Samsung HD Pro Heatsink Replacement: passo 11, immagine 1 di 1
    • Press each tab while using a plastic spudger to pry the motherboard up in the location near the tab.
  12. Samsung HD Pro Heatsink Replacement: passo 12, immagine 1 di 1
    • Unplug the final group of wires from the bottom of the second circuit board and remove the board.
  13. Samsung HD Pro Heatsink Replacement: passo 13, immagine 1 di 1
    • On reverse side of second circuit board, locate secondary heatsink.
  14. Samsung HD Pro Heatsink Replacement: passo 14, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the screws holding the heatsink to the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 272
