Salta al contenuto principale
Samsung Gravity TXT microSD Card Replacement
Cosa ti serve
  1. Samsung Gravity TXT microSD Card  Replacement, Battery: passo 1, immagine 1 di 2 Samsung Gravity TXT microSD Card  Replacement, Battery: passo 1, immagine 2 di 2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
  2. Samsung Gravity TXT microSD Card  Replacement: passo 2, immagine 1 di 1
    • Lift the back cover away from the main body of the phone.
  3. Samsung Gravity TXT microSD Card  Replacement: passo 3, immagine 1 di 1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
  4. Samsung Gravity TXT microSD Card  Replacement, microSD Card: passo 4, immagine 1 di 3 Samsung Gravity TXT microSD Card  Replacement, microSD Card: passo 4, immagine 2 di 3 Samsung Gravity TXT microSD Card  Replacement, microSD Card: passo 4, immagine 3 di 3
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
Conclusione
IUPUI, Team 1-1, Renguette SU 2015 Membro di IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 208
