Salta al contenuto principale
Samsung Glyde Motherboard Replacement
Cosa ti serve
  1. Samsung Glyde Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Samsung Glyde Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Samsung Glyde Motherboard Replacement, Motherboard: passo 3, immagine 1 di 2 Samsung Glyde Motherboard Replacement, Motherboard: passo 3, immagine 2 di 2
    • Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
  4. Samsung Glyde Motherboard Replacement: passo 4, immagine 1 di 2 Samsung Glyde Motherboard Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  5. Samsung Glyde Motherboard Replacement: passo 5, immagine 1 di 2 Samsung Glyde Motherboard Replacement: passo 5, immagine 2 di 2
    • The green film above the camera is the camera connector to the motherboard.
    • Use a plastic opening tool to disconnect the camera connector.
  6. Samsung Glyde Motherboard Replacement: passo 6, immagine 1 di 2 Samsung Glyde Motherboard Replacement: passo 6, immagine 2 di 2
    • The golden film connector connects the keyboard to the motherboard.
    • Use a plastic opening tool to disconnect the keyboard connector.
  7. Samsung Glyde Motherboard Replacement: passo 7, immagine 1 di 2 Samsung Glyde Motherboard Replacement: passo 7, immagine 2 di 2
    • The circular connector holds the motherboard in place.
    • Using a plastic opening tool, disconnect the circular connector.
  8. Samsung Glyde Motherboard Replacement: passo 8, immagine 1 di 3 Samsung Glyde Motherboard Replacement: passo 8, immagine 2 di 3 Samsung Glyde Motherboard Replacement: passo 8, immagine 3 di 3
    • There is a LCD connector underneath the motherboard.
    • Gently lift the far edge of the motherboard upwards toward the center of the phone.
    • Using a plastic opening tool, disconnect the LCD connector.
  9. Samsung Glyde Motherboard Replacement: passo 9, immagine 1 di 2 Samsung Glyde Motherboard Replacement: passo 9, immagine 2 di 2
    • After disconnecting the four connectors, gently lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
Conclusione
Stephen
Membro da: 10/12/11
26 Reputazione
1 Guida realizzata
Cal Poly, Team 3-12, Regan Fall 2011 Membro di Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,115
