Salta al contenuto principale
Samsung Gear VR USB Connector Replacement
  1. Samsung Gear VR USB Connector Replacement, USB Connector Replacement: passo 1, immagine 1 di 1
    • Remove front cover from headset.
  2. Samsung Gear VR USB Connector Replacement: passo 2, immagine 1 di 1
    • Slide the latch to the right to unlock the current connector.
  3. Samsung Gear VR USB Connector Replacement: passo 3, immagine 1 di 2 Samsung Gear VR USB Connector Replacement: passo 3, immagine 2 di 2
    • Lift connector clip away from headset and towards you.
    • Slide current connector out and away from headset until it is disconnected from connector clip.
  4. Samsung Gear VR USB Connector Replacement: passo 4, immagine 1 di 1
    • Select which connector fits the port of the device you wish to use with the Samsung Gear VR.
    • The Samsung Gear VR is packaged with connectors for Micro USB and USB-C.
  5. Samsung Gear VR USB Connector Replacement: passo 5, immagine 1 di 2 Samsung Gear VR USB Connector Replacement: passo 5, immagine 2 di 2
    • Slide the connector that connects to your device back onto the connector clip until you feel it settle into place.
    • Slide the lock latch to the left to secure the connector into place.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S4-G6, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Membri
7 Guide realizzate
5 Commenti
Hola, quisiera saber donde se consigue esa parte, ni siquiera en samsung lo he logrado
Jose Davinci - Replica
Were do I get the USB c adapter
helenpaul77 - Replica
If you want USB c adapter I can give you…but we have to make exchange because I need micro usb adapter not type c
Molefi Aaron -
I have the micro USB adapter and need type c. Please advise as to how this barter may be executed?
Saleem A. Sheikh -
Where can I get micro USB converter for gear vr not type c
Molefi Aaron - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 57
Tutti i Tempi: 16,374
