Salta al contenuto principale
Samsung Gear VR Front Phone Mount Replacement
Cosa ti serve
  1. Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: passo 1, immagine 1 di 3 Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: passo 1, immagine 2 di 3 Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: passo 1, immagine 3 di 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR Front Phone Mount Replacement: passo 2, immagine 1 di 2 Samsung Gear VR Front Phone Mount Replacement: passo 2, immagine 2 di 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
Conclusione
USF Tampa, Team S4-G6, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,257
