Salta al contenuto principale
Samsung Gear VR Motherboard Replacement
Cosa ti serve
  1. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: passo 1, immagine 1 di 3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: passo 1, immagine 2 di 3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: passo 1, immagine 3 di 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR  Motherboard Replacement: passo 2, immagine 1 di 2 Samsung Gear VR  Motherboard Replacement: passo 2, immagine 2 di 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR  Motherboard Replacement, Motherboard: passo 3, immagine 1 di 1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR  Motherboard Replacement: passo 4, immagine 1 di 1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
Conclusione
David Forlano
Membro da: 09/25/17
119 Reputazione
1 Guida realizzata
USF Tampa, Team S4-G6, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Membri
7 Guide realizzate
Un commento
Any idea where I can get a replacement board? Searched but cant seem to find. Thanks!
bineesh2k - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,551
