Salta al contenuto principale
Samsung Gear S3 Frontier Wristband Replacement
Panoramica Video
  1. Samsung Gear S3 Frontier Wristband  Replacement, Wristband: passo 1, immagine 1 di 3 Samsung Gear S3 Frontier Wristband  Replacement, Wristband: passo 1, immagine 2 di 3 Samsung Gear S3 Frontier Wristband  Replacement, Wristband: passo 1, immagine 3 di 3
    • Place the watch screen-down so that its back cover is showing.
    • Use your nail to push the small silver ball bearing on the right side downward.
    • If your nails aren't sharp enough, you can use a sharp pointed object such as a toothpick or pen.
    • While the ball is pressed down, pull the wristband outwards until the strap is disconnected from the main frame.
    • For reassembly, hold the ball down and then wedge each pin on the wristband into the pin holes of the main frame.
    • Follow the same steps for the ball on the left side, except this time push the ball upwards and then pull outwards.
Conclusione
Altre 2 persone hanno completato questa guida.
Corey Rumbaugh
Membro da: 10/08/18
1.507 Reputazione
1 Guida realizzata
Cal Poly, Team S15-G2, White Fall 2018 Membro di Cal Poly, Team S15-G2, White Fall 2018
CPSU-WHITE-F18S15G2
4 Membri
34 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 40
Tutti i Tempi: 2,806
