Salta al contenuto principale
Samsung Gear S2 Watch Strap Replacement
Cosa ti serve
  1. Samsung Gear S2 Watch Strap Replacement, Watch Strap: passo 1, immagine 1 di 2 Samsung Gear S2 Watch Strap Replacement, Watch Strap: passo 1, immagine 2 di 2
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Watch Strap Replacement: passo 2, immagine 1 di 2 Samsung Gear S2 Watch Strap Replacement: passo 2, immagine 2 di 2
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Watch Strap Replacement: passo 3, immagine 1 di 2 Samsung Gear S2 Watch Strap Replacement: passo 3, immagine 2 di 2
    • Repeat the procedure from step 2 for the other strap.
Conclusione
Altre 7 persone hanno completato questa guida.
Jacob Baldwin
Membro da: 02/20/17
3.412 Reputazione
5 Guide realizzate
USF Tampa, Team S2-G3, Sullivan Spring 2017 Membro di USF Tampa, Team S2-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G3
3 Membri
23 Guide realizzate
6 Commenti
can you also provide instruction to change home button on Gear S2
thanks
inder kapoor - Replica
you have to buy the continuing transfunctioner to change the home button on the gear s2
i have some for sale if interested
bobby - Replica
Where can you buy new straps?
Olga Andreu - Replica
Ebay Amazon etc.
Jens Troemer - Replica
YOU DO NOT NEED TO REMOVE THE SCREWS. Step 1 is completely irrelevant.
Ryo Kimball - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 87
Tutti i Tempi: 9,338
