Introduzione
This is just a look into the Samsung gear S2.
Strumenti
Parti
Nessuna parte specificata.
You will need a Y 00 screwdriver, a PH 0 screwdriver, a spudger, and some tweezers.
Pry between the bottom and top portions of the watch with a spudger in the area marked. Be sure not to insert the spudger more than about 3 mm so as not to damage the internals of the watch.
Also, there is a seal inside the watch that goes along the perimeter inside the bottom of the casing. Be sure not to damage this, otherwise you lose water resistance.
Altre 20 persone hanno completato questa guida.
24 Commenti
Thank you for a picture of the internals. I'm thinking about "restoring" a Gear S2 classic.
How do I replace the screen? It seems like it’s glued on.
Hi Austin, tks for making the guide, How to remove the rotating bezel?
