Salta al contenuto principale
Introduzione
If the heart rate monitor on the watch no longer detects your heart rate, then replacing the back may fix it.
  1. Flip the watch over so that the face is down. Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Using your finger, push forward on the release while pulling up on the strap. You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  4. Repeat the procedure from step 2 for the other strap. Repeat the procedure from step 2 for the other strap.
    • Repeat the procedure from step 2 for the other strap.
  5. Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back. Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
    • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
    • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
Conclusione
Jacob Baldwin
Membro da: 20/02/2017
2.292 Reputazione
5 Guide realizzate
USF Tampa, Team S2-G3, Sullivan Spring 2017 Membro di USF Tampa, Team S2-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G3
3 Membri
18 Guide realizzate
And where do you get the new replacement back? And does it just snap back on?
shawntravis76 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 238
