Salta al contenuto principale
Samsung Gear S Display Assembly Replacement
Cosa ti serve
  1. Samsung Gear S Display Assembly Replacement, Display Assembly: passo 1, immagine 1 di 3 Samsung Gear S Display Assembly Replacement, Display Assembly: passo 1, immagine 2 di 3 Samsung Gear S Display Assembly Replacement, Display Assembly: passo 1, immagine 3 di 3
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
  2. Samsung Gear S Display Assembly Replacement: passo 2, immagine 1 di 2 Samsung Gear S Display Assembly Replacement: passo 2, immagine 2 di 2
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
  3. Samsung Gear S Display Assembly Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
  4. Samsung Gear S Display Assembly Replacement: passo 4, immagine 1 di 1
    • Locate the ribbon assembly attaching the display to the motherboard.
  5. Samsung Gear S Display Assembly Replacement: passo 5, immagine 1 di 1
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
  6. Samsung Gear S Display Assembly Replacement: passo 6, immagine 1 di 1
    • Now the watch should be in three separate pieces.
Conclusione
To reassemble your device, follow these instructions in reverse order. You will need an adhesive to connect the screen back to the rest of the watch.
Altre 19 persone hanno completato questa guida.
USF Tampa, Team 12-1, Blackwell Fall 2015 Membro di USF Tampa, Team 12-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G1
4 Membri
5 Guide realizzate
16 Commenti
Where can i get the LCD for Gear S
Kuek See Chuan - Replica
my screen flashing light and show on screen lines
avi mor - Replica
Hi my gear is showing the watch face setting then glitches to the photo setting and is not allowing me to use any other apps?
Mark Measures - Replica
My watch is doing the same thing. Did you get a fix for it?
steve Walks -
There are flashing yellow lights on the screen, could I fix that?
Alex - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 15,507
