Salta al contenuto principale
Samsung Gear Live Heart Rate Monitor Replacement
Cosa ti serve
  1. Samsung Gear Live Heart Rate Monitor Replacement, Lay the watch face-down: passo 1, immagine 1 di 1
    • Lay the watch face-down on a flat, stable surface.
  2. Samsung Gear Live Heart Rate Monitor Replacement, Remove the holding pin: passo 2, immagine 1 di 1
    • Press the watchband down against the work surface.
    • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
  3. Samsung Gear Live Heart Rate Monitor Replacement, Remove the watchband: passo 3, immagine 1 di 1
    • With the spring-loaded pin pressed in, the watch band should release easily.
    • Gently pull the band away from the body of the watch.
    • Repeat steps 2 and 3 for the opposite side.
  4. Samsung Gear Live Heart Rate Monitor Replacement, Locate the four screws: passo 4, immagine 1 di 1
    • With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
  5. Samsung Gear Live Heart Rate Monitor Replacement, Remove the 4 screws: passo 5, immagine 1 di 1
    • Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
  6. Samsung Gear Live Heart Rate Monitor Replacement, Pry off the back of the watch.: passo 6, immagine 1 di 1
    • Gently work the plastic opening tool under the top edge of the watch’s back cover.
  7. Samsung Gear Live Heart Rate Monitor Replacement, Lift off the back cover: passo 7, immagine 1 di 2 Samsung Gear Live Heart Rate Monitor Replacement, Lift off the back cover: passo 7, immagine 2 di 2
    • With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
  8. Samsung Gear Live Heart Rate Monitor Replacement, Set both halves of the watch aside: passo 8, immagine 1 di 1
    • Lay both halves of the watch body assembly face down (with internal components facing up).
  9. Samsung Gear Live Heart Rate Monitor Replacement, Pry away the ribbon cable: passo 9, immagine 1 di 2 Samsung Gear Live Heart Rate Monitor Replacement, Pry away the ribbon cable: passo 9, immagine 2 di 2
    • Locate the ribbon cable connector near the edge of the watch's case.
    • Using the plastic opening tool, gently pry the connector from the motherboard
  10. Samsung Gear Live Heart Rate Monitor Replacement, Remove the red spacers: passo 10, immagine 1 di 2 Samsung Gear Live Heart Rate Monitor Replacement, Remove the red spacers: passo 10, immagine 2 di 2
    • Using the plastic opening tool, gently pry away the red spacers.
    • Set the spacers aside.
  11. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the motherboard: passo 11, immagine 1 di 3 Samsung Gear Live Heart Rate Monitor Replacement, Pry up the motherboard: passo 11, immagine 2 di 3 Samsung Gear Live Heart Rate Monitor Replacement, Pry up the motherboard: passo 11, immagine 3 di 3
    • Insert the end of the plastic opening tool under the motherboard.
    • Gently pry up the motherboard.
  12. Samsung Gear Live Heart Rate Monitor Replacement, Remove the heart rate sensor cable: passo 12, immagine 1 di 2 Samsung Gear Live Heart Rate Monitor Replacement, Remove the heart rate sensor cable: passo 12, immagine 2 di 2
    • Set the motherboard on a flat, stable surface.
    • Using the plastic opening tool, gently pry the heart rate sensor cable from the motherboard.
  13. Samsung Gear Live Heart Rate Monitor Replacement, Pry up the heart rate sensor: passo 13, immagine 1 di 3 Samsung Gear Live Heart Rate Monitor Replacement, Pry up the heart rate sensor: passo 13, immagine 2 di 3 Samsung Gear Live Heart Rate Monitor Replacement, Pry up the heart rate sensor: passo 13, immagine 3 di 3
    • Once the cable is disconnected, run the plastic opening tool under the heart rate sensor from all sides, gently prying up as you go along.
Conclusione
Altre 3 persone hanno completato questa guida.
Keith Cooper
Membro da: 09/25/14
1.265 Reputazione
6 Guide realizzate
USF Tampa, Team 1-7, Brown Fall 2014 Membro di USF Tampa, Team 1-7, Brown Fall 2014
USFT-BROWN-F14S1G7
3 Membri
6 Guide realizzate
1Commento della guida
Check all of your guides to make sure you've indicate the needed tools.
Dan Brown - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,646
