Introduzione
Use this guide to remove the speaker from the Samsung Gear 360. You will need to complete an almost full tear-down of the device to get to the speaker, but you can safely remove it after separating the two cases.
Cosa ti serve
Within gold metal half of the case, unscrew the Phillips #00 0.75 mm screw located on the metal plate using a PH00 screwdriver.
Using a plastic opening tool, remove the metal cover.
Quasi finito!
Conclusione
