Salta al contenuto principale
Samsung Gear 360 Battery Replacement
  1. Samsung Gear 360 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Insert thumb under tab of battery cover.
    • Pull to remove the battery cover.
  2. Samsung Gear 360 Battery Replacement: passo 2, immagine 1 di 2 Samsung Gear 360 Battery Replacement: passo 2, immagine 2 di 2
    • Once the cover is opened, press index finger on the tab to release the battery from the battery slot.
  3. Samsung Gear 360 Battery Replacement: passo 3, immagine 1 di 1
    • Once the battery has popped out, pull the battery out of the camera.
Conclusione
Altre 2 persone hanno completato questa guida.
Angel Veras
Membro da: 02/20/17
107 Reputazione
1 Guida realizzata
USF Tampa, Team S3-G5, Sullivan Spring 2017 Membro di USF Tampa, Team S3-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G5
4 Membri
14 Guide realizzate
Un commento
I charged one battery successfully and proceeded to remove the battery and insert another battery to charge. The camera died and would not charge the second battery, so I re-inserted the charged battery and now the camera will not power up. Any ideas?
Mark Newsom - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 62
Tutti i Tempi: 6,624
