Salta al contenuto principale
Samsung Gear 2 Speaker Replacement
Cosa ti serve
  1. Samsung Gear 2 Speaker Replacement, Front half and Back half: passo 1, immagine 1 di 2 Samsung Gear 2 Speaker Replacement, Front half and Back half: passo 1, immagine 2 di 2
    • Before disassembling your Gear, be sure it is powered off.
    • To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
  2. Samsung Gear 2 Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  3. Samsung Gear 2 Speaker Replacement: passo 3, immagine 1 di 3 Samsung Gear 2 Speaker Replacement: passo 3, immagine 2 di 3 Samsung Gear 2 Speaker Replacement: passo 3, immagine 3 di 3
    • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
    • Pry the device open from the other side also if it does not fully disassemble from one side.
  4. Samsung Gear 2 Speaker Replacement, Battery: passo 4, immagine 1 di 2 Samsung Gear 2 Speaker Replacement, Battery: passo 4, immagine 2 di 2
    • Use the pointed side of the spudger to remove the small, orange battery cable.
  5. Samsung Gear 2 Speaker Replacement: passo 5, immagine 1 di 2 Samsung Gear 2 Speaker Replacement: passo 5, immagine 2 di 2
    • Remove the battery by pulling the white tab on the battery marked "PULL."
    • Make sure the orange battery cable is fully disconnected to avoid ripping it off and tearing it.
  6. Samsung Gear 2 Speaker Replacement, Speaker: passo 6, immagine 1 di 2 Samsung Gear 2 Speaker Replacement, Speaker: passo 6, immagine 2 di 2
    • Using tweezers, lift the rectangular speaker from the case.
    • Be careful to not pull too quickly and rip the orange connector cable, which is attached to the case with adhesive.
  7. Samsung Gear 2 Speaker Replacement: passo 7, immagine 1 di 2 Samsung Gear 2 Speaker Replacement: passo 7, immagine 2 di 2
    • Use tweezers to carefully grab the connector.
    • Gently pull upwards to detach it from the case and from the adhesive.
Conclusione
Altre 4 persone hanno completato questa guida.
Devin Mast
Membro da: 04/14/14
637 Reputazione
1 Guida realizzata
Cal Poly, Team 13-27, Maness Spring 2014 Membro di Cal Poly, Team 13-27, Maness Spring 2014
CPSU-MANESS-S14S13G27
4 Membri
6 Guide realizzate
3 Commenti
what happens if I don't put the speakers back?
alejandrayin5 - Replica
If you don't what the gear to make the sound when using camera or video take the speaker out. It works fine its just a speaker. I did that with my gear 2 that I bought march 2015.
Edna - Replica
Where can I buy the speaker?
Bob Wagenvoort - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 4,070
