Salta al contenuto principale
Samsung Galaxy Xcover GT-S5690 LCD Replacement
Cosa ti serve
  1. Samsung Galaxy Xcover GT-S5690 LCD Replacement, LCD: passo 1, immagine 1 di 1
    • Here is the Samsung Galaxy Xcover, with the LCD broken, that will be replaced.
  2. Samsung Galaxy Xcover GT-S5690 LCD Replacement: passo 2, immagine 1 di 1
    • The first step, is remove the battery door. It comes with a security lock, that has to be on open position. Start opening from bottom, and releasing from the side edges.
  3. Samsung Galaxy Xcover GT-S5690 LCD Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Xcover GT-S5690 LCD Replacement: passo 3, immagine 2 di 2
    • Remove with a flat screwdriver, the volume button and the power button
    • Now, with a Phillpis Screwdriver, remove all the screws from the backcover.
  4. Samsung Galaxy Xcover GT-S5690 LCD Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Xcover GT-S5690 LCD Replacement: passo 4, immagine 2 di 2
    • With a flat screwdriver or plastic opener, separate the front case from the rear case. It will be easy!
  5. Samsung Galaxy Xcover GT-S5690 LCD Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Xcover GT-S5690 LCD Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Xcover GT-S5690 LCD Replacement: passo 5, immagine 3 di 3
    • Remove the screw on the lower zone of the main board. The screw is the same of the case, so dont worry if you mix them.
    • Now, with a pliers, unplug the camera and the front speaker. Now, we are going to lift the main board, but ...
    • be careful, below is the LCD flex cable!
  6. Samsung Galaxy Xcover GT-S5690 LCD Replacement: passo 6, immagine 1 di 2 Samsung Galaxy Xcover GT-S5690 LCD Replacement: passo 6, immagine 2 di 2
    • Remove the LCD flat cable, and then, remove the 2 screws on the sides of the front cover. They are the same as the others screws...
    • Now, you can take apart the chassis from the front cover, leaving only the display and the touch.
  7. Samsung Galaxy Xcover GT-S5690 LCD Replacement: passo 7, immagine 1 di 2 Samsung Galaxy Xcover GT-S5690 LCD Replacement: passo 7, immagine 2 di 2
    • Lift up the black retainer, and take off the touch flex cable.
    • Be careful, the flex has double side tape below the IC.
    • Now, with a knife or cutter, lift carefully the LCD unit. Place the new LCD, and reassembly the phone.
    • In the near future, I´ll post how to replace the touch screen!
Conclusione
Altre 3 persone hanno completato questa guida.
Jaime
Membro da: 11/05/13
3.333 Reputazione
4 Guide realizzate
1Commento della guida
Good and clear. Pics are much better than movie, thank you very much!
pierrequivoyage - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 42
Tutti i Tempi: 7,325
