Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Use this guide to replace a cracked or broken screen on your Galaxy Watch.
  1. Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
  2. Use an opening tool to get between the back cover and the metal housing of the watch. Carefully pry the plastic back cover open.
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
  3. Lay down the watch and lift the back cover to access the sensor connector on the motherboard. Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. Use a spudger to disconnect the sensor flex cable from the motherboard. Use a spudger to disconnect the sensor flex cable from the motherboard.
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
  6. Remove the back cover. When closing the watch make sure the rubber gasket is undamaged or replace it with a new one. When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
  7. Use a spudger to disconnect the display flex cable from the motherboard. Use a spudger to disconnect the display flex cable from the motherboard.
    • Use a spudger to disconnect the display flex cable from the motherboard.
  8. Lift the core unit out of the housing. The core's plastic frame sits tight inside the housing.
    • Lift the core unit out of the housing.
    • The core's plastic frame sits tight inside the housing.
    • Carefully thread the display flex cable through the gap of the core's plastic frame.
  9. If necessary apply some tape over the display to avoid any injury from glass shards.
    • If necessary apply some tape over the display to avoid any injury from glass shards.
  10. Use your finger or thumb to steadily push down on the display to loosen the adhesive. Heating the display with a hair dryer or iOpener helps softening the adhesive.
    • Use your finger or thumb to steadily push down on the display to loosen the adhesive.
    • Heating the display with a hair dryer or iOpener helps softening the adhesive.
    • Remove the display.
Conclusione
Altre 2 persone hanno completato questa guida.
Tobias Isakeit
Membro da: 31/03/2014
74.102 Reputazione
142 Guide realizzate
iFixit Membro di iFixit
Community
128 Membri
13.120 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 21
Ultimi 7 Giorni: 114
Ultimi 30 Giorni: 528
Tutti i Tempi: 1,025
