Salta al contenuto principale
Samsung Galaxy View Speakers Replacement
Cosa ti serve
  1. Samsung Galaxy View Speakers Replacement, Kickstand: passo 1, immagine 1 di 1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Speakers Replacement: passo 2, immagine 1 di 3 Samsung Galaxy View Speakers Replacement: passo 2, immagine 2 di 3 Samsung Galaxy View Speakers Replacement: passo 2, immagine 3 di 3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
  3. Samsung Galaxy View Speakers Replacement, Battery: passo 3, immagine 1 di 2 Samsung Galaxy View Speakers Replacement, Battery: passo 3, immagine 2 di 2
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
  4. Samsung Galaxy View Speakers Replacement: passo 4, immagine 1 di 3 Samsung Galaxy View Speakers Replacement: passo 4, immagine 2 di 3 Samsung Galaxy View Speakers Replacement: passo 4, immagine 3 di 3
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
  5. Samsung Galaxy View Speakers Replacement: passo 5, immagine 1 di 3 Samsung Galaxy View Speakers Replacement: passo 5, immagine 2 di 3 Samsung Galaxy View Speakers Replacement: passo 5, immagine 3 di 3
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
  6. Samsung Galaxy View Speakers Replacement: passo 6, immagine 1 di 2 Samsung Galaxy View Speakers Replacement: passo 6, immagine 2 di 2
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
  7. Samsung Galaxy View Speakers Replacement: passo 7, immagine 1 di 3 Samsung Galaxy View Speakers Replacement: passo 7, immagine 2 di 3 Samsung Galaxy View Speakers Replacement: passo 7, immagine 3 di 3
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  8. Samsung Galaxy View Speakers Replacement, Speakers: passo 8, immagine 1 di 3 Samsung Galaxy View Speakers Replacement, Speakers: passo 8, immagine 2 di 3 Samsung Galaxy View Speakers Replacement, Speakers: passo 8, immagine 3 di 3
    • Use the plastic opening tool to disconnect the white bundled cable connector that links the left speaker to the motherboard via a red wire.
    • Remove the left speaker by gripping it with your hand and lifting it off of the pegs.
  9. Samsung Galaxy View Speakers Replacement: passo 9, immagine 1 di 2 Samsung Galaxy View Speakers Replacement: passo 9, immagine 2 di 2
    • Remove the right speaker by gripping it with your hand and pulling it straight up and off of the pegs.
    • The white bundled wire connector, and the red wire attaching the speaker to the motherboard, will come off when lifting the speaker.
Conclusione
Cal Poly, Team 4-5, Livingston Fall 2016 Membro di Cal Poly, Team 4-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G5
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,073
