Salta al contenuto principale
Samsung Galaxy View Motherboard Replacement
Cosa ti serve
  1. Samsung Galaxy View Motherboard Replacement, Kickstand: passo 1, immagine 1 di 1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Motherboard Replacement: passo 2, immagine 1 di 3 Samsung Galaxy View Motherboard Replacement: passo 2, immagine 2 di 3 Samsung Galaxy View Motherboard Replacement: passo 2, immagine 3 di 3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
  3. Samsung Galaxy View Motherboard Replacement, Battery: passo 3, immagine 1 di 2 Samsung Galaxy View Motherboard Replacement, Battery: passo 3, immagine 2 di 2
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
  4. Samsung Galaxy View Motherboard Replacement: passo 4, immagine 1 di 3 Samsung Galaxy View Motherboard Replacement: passo 4, immagine 2 di 3 Samsung Galaxy View Motherboard Replacement: passo 4, immagine 3 di 3
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
  5. Samsung Galaxy View Motherboard Replacement: passo 5, immagine 1 di 3 Samsung Galaxy View Motherboard Replacement: passo 5, immagine 2 di 3 Samsung Galaxy View Motherboard Replacement: passo 5, immagine 3 di 3
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
  6. Samsung Galaxy View Motherboard Replacement: passo 6, immagine 1 di 2 Samsung Galaxy View Motherboard Replacement: passo 6, immagine 2 di 2
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
  7. Samsung Galaxy View Motherboard Replacement: passo 7, immagine 1 di 3 Samsung Galaxy View Motherboard Replacement: passo 7, immagine 2 di 3 Samsung Galaxy View Motherboard Replacement: passo 7, immagine 3 di 3
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  8. Samsung Galaxy View Motherboard Replacement, Speakers: passo 8, immagine 1 di 3 Samsung Galaxy View Motherboard Replacement, Speakers: passo 8, immagine 2 di 3 Samsung Galaxy View Motherboard Replacement, Speakers: passo 8, immagine 3 di 3
    • Use the plastic opening tool to disconnect the white bundled cable connector that links the left speaker to the motherboard via a red wire.
    • Remove the left speaker by gripping it with your hand and lifting it off of the pegs.
  9. Samsung Galaxy View Motherboard Replacement: passo 9, immagine 1 di 2 Samsung Galaxy View Motherboard Replacement: passo 9, immagine 2 di 2
    • Remove the right speaker by gripping it with your hand and pulling it straight up and off of the pegs.
    • The white bundled wire connector, and the red wire attaching the speaker to the motherboard, will come off when lifting the speaker.
  10. Samsung Galaxy View Motherboard Replacement, Motherboard: passo 10, immagine 1 di 2 Samsung Galaxy View Motherboard Replacement, Motherboard: passo 10, immagine 2 di 2
    • Insert the plastic opening tool beneath the orange press-fit connector attached to the bottom left side of the motherboard and use a leverage motion to pry the connector from the board.
    • Repeat the above step for the other two orange press-fit connectors attached on the bottom left side of the motherboard.
  11. Samsung Galaxy View Motherboard Replacement: passo 11, immagine 1 di 2 Samsung Galaxy View Motherboard Replacement: passo 11, immagine 2 di 2
    • Use the plastic opening tool to pry up on the blue antenna cable connector near the right edge of the motherboard.
    • Repeat the above for the black antenna cable connector positioned next to the blue wire.
  12. Samsung Galaxy View Motherboard Replacement: passo 12, immagine 1 di 3 Samsung Galaxy View Motherboard Replacement: passo 12, immagine 2 di 3 Samsung Galaxy View Motherboard Replacement: passo 12, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the nine 3 mm screws around the motherboard.
    • There is a metal bracket beneath four of the screws on the right side of motherboard. This bracket will also be removed during this step.
  13. Samsung Galaxy View Motherboard Replacement: passo 13, immagine 1 di 1
    • Lift the motherboard straight up to remove it from the device.
Conclusione
Altre 16 persone hanno completato questa guida.
Cal Poly, Team 4-5, Livingston Fall 2016 Membro di Cal Poly, Team 4-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G5
4 Membri
12 Guide realizzate
5 Commenti
Hi… Where can I get a replacement motherboard for a Samsung galaxy view? I need one.
Ryan Mitchell - Replica
DITTO that I need a new mother board as well. Where can we purchase it?
Lori Marr - Replica
Hello I need the charger plugin and wire harness replacement parts. there tiny heres a screen shot of what is needed. If anyone knows where please posts info in reply thank you
[img]https://i.imgur.com/QMgrXkh.jpg[/img]
wildcar - Replica
where can you find a replacement motherboard. seems like all you can you is buy a used one off ebay.
chiming tse - Replica
where can you buy a replacement motherboard. seems like only way is to buy a used unit off ebay.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 33
Tutti i Tempi: 6,780
