Salta al contenuto principale
Samsung Galaxy View Kickstand Replacement
Cosa ti serve
  1. Samsung Galaxy View Kickstand Replacement, Kickstand: passo 1, immagine 1 di 1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Kickstand Replacement: passo 2, immagine 1 di 3 Samsung Galaxy View Kickstand Replacement: passo 2, immagine 2 di 3 Samsung Galaxy View Kickstand Replacement: passo 2, immagine 3 di 3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 4-5, Livingston Fall 2016 Membro di Cal Poly, Team 4-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G5
4 Membri
12 Guide realizzate
15 Commenti
Where do u buy a replacement kickstand
Bethann Stokes - Replica
The only thing I could find was a broken one on eBay for parts ......
cindylou73 -
I have the same issue! kickstand broke in half (it fell and got broken) and cannot find replacement
Carlos Sierra -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 37
Tutti i Tempi: 8,688
