Salta al contenuto principale
Samsung Galaxy Victory 4G Screen Replacement
Cosa ti serve
  1. Samsung Galaxy Victory 4G Screen Replacement, Screen: passo 1, immagine 1 di 3 Samsung Galaxy Victory 4G Screen Replacement, Screen: passo 1, immagine 2 di 3 Samsung Galaxy Victory 4G Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Place the phone face down. Ensure that the side with the display screen is not facing you.
    • Locate the back door and slide open.
    • Remove the battery.
  2. Samsung Galaxy Victory 4G Screen Replacement: passo 2, immagine 1 di 1
    • Remove the 7 Phillips 3.93 mm labeled screws by using the Phillips #00 Precision Screwdriver.
  3. Samsung Galaxy Victory 4G Screen Replacement: passo 3, immagine 1 di 1
    • Use the plastic opening tool to pry open the back cover.
    • Insert the tool into the SD card slot and pry around the entire phone.
  4. Samsung Galaxy Victory 4G Screen Replacement: passo 4, immagine 1 di 1
    • Remove one Phillips 3.93 mm screw from the bottom center of the phone.
  5. Samsung Galaxy Victory 4G Screen Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Victory 4G Screen Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Victory 4G Screen Replacement: passo 5, immagine 3 di 3
    • Carefully disconnect the 3 labeled ribbons. To remove, place tool under the ribbon and pull slowly to avoid tearing.
  6. Samsung Galaxy Victory 4G Screen Replacement: passo 6, immagine 1 di 2 Samsung Galaxy Victory 4G Screen Replacement: passo 6, immagine 2 di 2
    • Pull the motherboard back and out to the left. Make sure the motherboard is faced straight up, as shown in the photo.
    • Place your tool under the labeled ribbon and pull gently to detach the ribbon cable from the motherboard.
    • At this point, the motherboard should be completely detached from the rest of the phone.
  7. Samsung Galaxy Victory 4G Screen Replacement: passo 7, immagine 1 di 2 Samsung Galaxy Victory 4G Screen Replacement: passo 7, immagine 2 di 2
    • Next, detach the labeled cable . Pull gently on the black gate and use a tool to pull out the cable.
    • Detach the labeled digitizer chip by gently prying a tool under the chip and pulling it up and out.
  8. Samsung Galaxy Victory 4G Screen Replacement: passo 8, immagine 1 di 1
    • Heat iOpener in microwave for one minute on the highest power setting. Let the iOpener sit on the device for about 90 seconds. This step is necessary to loosen the glue under the display screen. Be careful, the glue is very sticky!
  9. Samsung Galaxy Victory 4G Screen Replacement: passo 9, immagine 1 di 1
    • Place the suction cup on the screen. Make sure not to place the cup on the cracked area.
  10. Samsung Galaxy Victory 4G Screen Replacement: passo 10, immagine 1 di 1
    • Pull gently to detach the screen.
    • Once detached, gently remove the ribbon from the shown slot. At this point, you can replace the cracked screen with a new one.
Conclusione
Altre 4 persone hanno completato questa guida.
Zhao
Membro da: 09/23/14
251 Reputazione
2 Guide realizzate
USF Tampa, Team 15-3, Remmell Fall 2014 Membro di USF Tampa, Team 15-3, Remmell Fall 2014
USFT-REMMELL-F14S15G3
4 Membri
3 Guide realizzate
Un commento
Info correct - replaced my screen no prob.
George Kuch - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,910
