Salta al contenuto principale
Samsung Galaxy Victory 4G Motherboard Replacement
Cosa ti serve
  1. Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Place phone face down. Ensure the side with the display screen is not facing you.
    • Locate battery door and slide open.
    • Remove battery.
  2. Samsung Galaxy Victory 4G Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the 7 Phillips 3.93 mm labeled screws by using the Phillips #00 Precision Screwdriver.
  3. Samsung Galaxy Victory 4G Motherboard Replacement: passo 3, immagine 1 di 1
    • Use the plastic opening tool to pry open the back cover.
    • Insert the tool into the SD card slot and pry around the entire phone.
  4. Samsung Galaxy Victory 4G Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove one Phillips 3.93 mm screw from bottom center of the phone.
  5. Samsung Galaxy Victory 4G Motherboard Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Victory 4G Motherboard Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Victory 4G Motherboard Replacement: passo 5, immagine 3 di 3
    • Carefully disconnect 3 ribbons at the shown location. To remove, place tool under the ribbon and pull slowly to avoid tearing.
  6. Samsung Galaxy Victory 4G Motherboard Replacement: passo 6, immagine 1 di 2 Samsung Galaxy Victory 4G Motherboard Replacement: passo 6, immagine 2 di 2
    • Pull the motherboard back and out to the left. Make sure the motherboard is faced straight up, as shown in the photo.
    • Place your tool under the labeled area and pull gently to detach the ribbon cable from the motherboard.
    • At this point the motherboard should be completely detached from the rest of the phone.
Conclusione
Altre 6 persone hanno completato questa guida.
Zhao
Membro da: 09/23/14
251 Reputazione
2 Guide realizzate
USF Tampa, Team 15-3, Remmell Fall 2014 Membro di USF Tampa, Team 15-3, Remmell Fall 2014
USFT-REMMELL-F14S15G3
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,607
