Salta al contenuto principale
Introduzione
Use this guide to replace a cracked or malfunctioning display on your Samsung Galaxy Tab S3 tablet (identified with model number SM-T820).
The display assembly is the output component to present information and is made up of the glass panel, digitizer, and AMOLED display sandwiched together. Your display may need to be replaced if the glass cracks or is broken because this will affect its touch screen capabilities. It could also experience something called “screen burn-in” that happens on AMOLED displays. “Screen burn-in” is when some of the individual light-emitting pixels powering the display will dim the more they are used, causing uneven lighting and colors.
In step 1 of this guide, you will need to use the iOpener, which is a microwavable heating tool used to loosen adhesive attached to the display. Carefully follow the iOpener heating instructions to avoid burning yourself. If your display is shattered, follow this guide to reinforce your screen to avoid injury until you replace the display. Make sure to power off your laptop completely and disconnect from any external power source prior to beginning this guide.
  1. To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device.
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device.
    • We used two iOpeners to open up the tablet. The process is doable with a single iOpener, but would take substantially longer. Alternatively, you can use a heat gun to quickly loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
    There is no reason to remove the screen while replacing a battery.
    Nick Youngstrom - Replica
  2. Place a suction cup near edge that you heated up with the iOpener.
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. As you continue along the edge using the opening tool, use a plastic card  to keep the glass separate from the midframe.
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  5. As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display. Pull off the glass panel using the suction cup. Carefully disconnect the ribbon connecting the display assembly to the motherboard.  You can disconnect this ribbon from either end.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Pull off the glass panel using the suction cup.
    • Carefully disconnect the ribbon connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  6. Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device. Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Conclusione
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
Altre 3 persone hanno completato questa guida.
Jelly Romero
Membro da: 19/04/2018
217 Reputazione
1 Guida realizzata
Cal Poly, Team S22-G4, Maness Spring 2018 Membro di Cal Poly, Team S22-G4, Maness Spring 2018
CPSU-MANESS-S18S22G4
5 Membri
10 Guide realizzate
Thank you so much, It helped me so much.
MRxROBOT - Replica
What if the digitizer is ok and only the glass cover is cracked
stargazer_jbl - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 134
Ultimi 30 Giorni: 595
Tutti i Tempi: 8,077
