Introduzione
If your home button is no longer functioning properly, it may have become worn or gotten stuck over time, this guide can help you replace it.
Cosa ti serve
Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
Unclip the orange ribbon cable located above the battery using the Blunt ESD Tweezer.
Remove the four black 3mm screws using a PH000 Phillips screwdriver.
Quasi finito!
Conclusione
