Introduzione
Broken speakers prevent your tablet from producing quality sound or any sound at all. Removing the speakers may require an iOpener or a heat gun. Check out this iOpener guide for instructions on how to use it.
Cosa ti serve
Apply the heat gun around the edges of the tablet to melt the adhesive glue.
Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
Locate the speakers towards the bottom.
For the speaker on the left, use the plastic opening tool to lift up the press-fit connector.
Altre 3 persone hanno completato questa guida.
