Introduzione
A broken headphone jack means that audio from your headphones is poor or nonexistent.
Cosa ti serve
Apply the heat gun around the edges of the tablet to melt the adhesive glue.
Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
Locate the headphone jack towards the bottom right-hand side.
Using the plastic opening tool, lift up the press-fit connector.
Altre 2 persone hanno completato questa guida.
