Introduzione
If the tablet is not staying on unless plugged in, replacing the battery should solve the problem.
Cosa ti serve
Apply heat using an iFixit iOpener or another heating gun in order to weaken the adhesive around the edges of the screen.
Insert the plastic opening tool into the gap between the screen and tablet in the location where you want to start removing the screen.
Put an opening pick in the gap created, in between the screen and the panel.
Repeat all around device, putting 2 picks on top and bottom, and one on each side.
Remove the 13 3mm screws from around the edges of the board using a Phillips #1 screwdriver head.
Lift up and remove the panel of the board using a plastic opening tool.
Altre 15 persone hanno completato questa guida.
15 Commenti
Humm u’ve just had to remove the back cover the battery is here no need to remove the screen
OMG thank you I definitely would have followed the instructions you’re absolutely right the back just case clips and comes off fairly easy
Thank you. OH GOD thank you.
This isn’t true with this model. You have the Exnyos one. The Qualcomm one does not have a removable back..
JM M -
