Salta al contenuto principale
Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: passo 1, immagine 1 di 2 Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: passo 1, immagine 2 di 2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: passo 2, immagine 1 di 1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: passo 3, immagine 1 di 1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: passo 4, immagine 1 di 2 Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: passo 4, immagine 2 di 2
    • Gently pry the camera connector away from the motherboard with a plastic opening tool or your fingers.
    • Lift the rear-facing camera module up and away from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Trent Chapman
Membro da: 10/01/15
1.378 Reputazione
3 Guide realizzate
Cal Poly, Team 12-15, Maness Fall 2015 Membro di Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,439
