Salta al contenuto principale
Samsung Galaxy Tab S 8.4 Back Cover Replacement
Cosa ti serve
  1. Samsung Galaxy Tab S 8.4 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 2 Samsung Galaxy Tab S 8.4 Back Cover Replacement, Back Cover: passo 1, immagine 2 di 2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Back Cover Replacement: passo 2, immagine 1 di 1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Back Cover Replacement: passo 3, immagine 1 di 1
    • Remove the back cover after the entire rim is disconnected.
Conclusione
Altre 12 persone hanno completato questa guida.
Cal Poly, Team 12-15, Maness Fall 2015 Membro di Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
4 Membri
12 Guide realizzate
3 Commenti
This is great and the process works fine. The query is where does one purchase a new back cover
Alan - Replica
Hi, where can I buy the back cover of Samsung galaxy tab S 8.4. Tnx
Abe Madrigal - Replica
Hi, where can I buy the back cover of Samsung galaxy tab s 8.4. Ty
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 59
Tutti i Tempi: 13,322
