Salta al contenuto principale
Samsung Galaxy Tab Pro 8.4 Motherboard Replacement
Cosa ti serve
  1. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 2, immagine 2 di 2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 4, immagine 1 di 1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 5, immagine 1 di 1
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: passo 6, immagine 2 di 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: passo 6, immagine 3 di 3
    • Remove all the clips that are attached to the motherboard using your fingers or a nylon spudger.
  7. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 7, immagine 1 di 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 7, immagine 2 di 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 7, immagine 3 di 3
    • There are four Phillips head screws (2.5mm) that need to be removed:
    • Two on the charging port, which is the small metallic piece at the bottom of the device.
    • There is one screw that is covered by a small green tape. The tape must be peeled off before the screw under can be removed.
    • The last screw is found on a speaker at the bottom right of the device. Once the screw is removed, the speaker must be removed as well.
  8. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 8, immagine 1 di 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 8, immagine 2 di 3 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 8, immagine 3 di 3
    • There is a small wire that connects the motherboard to the bottom right corner.
    • Gently pull the end of the wire that attaches the motherboard to the device until the wire is disconnected.
    • After the cord is disconnected, the motherboard can be removed from the tablet by simply lifting it from the device.
Linea Traguardo
Altre 5 persone hanno completato questa guida.
USF Tampa, Team 9-2, Lacy Fall 2016 Membro di USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,389
