Salta al contenuto principale
Samsung Galaxy Tab Pro 8.4 Charging Port Replacement
Cosa ti serve
  1. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Battery: passo 1, immagine 1 di 1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 2, immagine 2 di 2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 3, immagine 2 di 2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 4, immagine 1 di 1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 5, immagine 1 di 1
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: passo 6, immagine 1 di 2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: passo 6, immagine 2 di 2
    • Remove the two 2.5mm Phillips #000 screws.
  7. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 7, immagine 1 di 3 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 7, immagine 2 di 3 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 7, immagine 3 di 3
    • Gently pull up on tab that connects the charging port to the motherboard
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team 9-2, Lacy Fall 2016 Membro di USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
4 Membri
10 Guide realizzate
3 Commenti
Thank you for your help. You are awesome :-)
Kim Williams - Replica
I did all of this and battery says “not charging” while plugged in. Replaced both battery and port.
Brandon Torzeski - Replica
Hey Thanks guys! I was interested in the data port / charging port flex cable replacement.
It could not be easier. Cheers folks.
Jim Kirkey
Jim Kirkey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 4,060
