Salta al contenuto principale
Samsung Galaxy Tab Pro 8.4 Battery Replacement
Cosa ti serve
  1. Samsung Galaxy Tab Pro 8.4 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Battery Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Tab Pro 8.4 Battery Replacement: passo 2, immagine 2 di 2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Battery Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Tab Pro 8.4 Battery Replacement: passo 3, immagine 2 di 2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Battery Replacement: passo 4, immagine 1 di 1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Battery Replacement: passo 5, immagine 1 di 1
    • The battery should be completely disconnected and the new one can be installed.
Conclusione
Altre 21 persone hanno completato questa guida.
USF Tampa, Team 9-2, Lacy Fall 2016 Membro di USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
4 Membri
10 Guide realizzate
Un commento
Samsung Galaxy tab ki battery 4800 mah
Razwan good ashqui - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 37
Tutti i Tempi: 12,169
