Salta al contenuto principale
Samsung Galaxy Tab E Lite 7 Kids Battery Replacement
Cosa ti serve
  1. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: passo 1, immagine 1 di 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: passo 1, immagine 2 di 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: passo 1, immagine 3 di 3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 2, immagine 2 di 2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: passo 3, immagine 1 di 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: passo 3, immagine 2 di 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: passo 3, immagine 3 di 3
    • Use the plastic opening tool to gently lift the black ZIF (zero insertion force) connector shown within the red circle.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 4, immagine 2 di 2
    • Use the plastic opening tool to gently lift black ZIF (zero insertion force) connector shown within the red square.
    • Now gently pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 5, immagine 3 di 3
    • Use the plastic opening tool and gently pry out the battery from the left-hand side.
    • Grab the battery and lift it up.
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team S19-G2, Hoffman Spring 2017 Membro di USF Tampa, Team S19-G2, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G2
4 Membri
7 Guide realizzate
Un commento
Great information.  You need to show how to replace a screen- LCD for a Samsung Galaxy TAB E Lite Kids.
Paul McWilliams - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 3,026
