Introduzione
This procedure is relatively straight forward. You should take care to place the display on a soft surface and it is always advisable to use an anti-static bracelet, or an antistatic station to protect delicate circuitry from static discharge.
Cosa ti serve
Panoramica Video
Insert one of the blue plastic opening tools between the glass display and the edge of the tablet's outer shell to break the seal around the display. It doesn't matter where you start the process, but once you form a gap, continue opening the gap around the edge of the device.
The display assembly and back casing should gently come apart after a gap is formed around the perimeter.
Attached to the back side of the display you will find the all of the primary computer hardware including the battery. You will need to remove six 3-millimeter Phillips head PH000 screws and two ribbon cables.
The first ribbon cable to remove is the longer of the two. It overlaps the entire battery. It is marked in orange in the Step 2 image.
Using the precision tweezers gently remove the green tape over the clip at the end of the ribbon cable.
Last, gently lift the clip lever and the ribbon cable should should easily slide out from its slot.
Once all the 6 screws and 2 ribbons are removed, the battery should come free of the display assembly very easily.
With one hand on each side of the tablet simply turn the device on edge with one hand and tilt it over until the battery falls into your other hand.
If for some reason the battery does not come out, double check to ensure you have removed and unattached all of the 6 screws and 2 ribbon cables.
Altre 30 persone hanno completato questa guida.
10 Commenti
Here are some tips to pry the cover off without damaging the digitizer: the cover is cemented with adhesive tape, making it hard to insert a tool into the seam, so heat the edge only first. Once you have it warm (not hot), use all of your fingers on the power button side to pull the plastic edge, using your thumbs to press on the back - do not try to pry or press against the glass side. Also, do not slide the pry tool under the glass and lift up, you can crack the glass. It takes patience
"Warm, not hot," is roughly between 175 - 200 degrees Fahrenheit. (80 to 100 Celsius).
First step is not easy. Do what seadawg did above. Dont bother with plastic tools. Start near the power button. Dont try to go between the screen and tablet. Pull back the plastic instead. I wish I had read seadawgs advice first, would have saved me a digitiser and a load of time…
Where do u even get the tools? also how is this supposed to work if everyones saying it will crack the screen?
Heat gun available at most any hardware store, walmart sells an electronics repair tool kit for $15 USD with all the other tools you'd ever need including the screwdriver bits for Nintendo products too!
It did not work for me… :(
What is the ribbon cable that goes from one end to the other of the battery? Tab is saying temperature is too hot and will not charge, but it says it anytime plugging in to charge. The temp sensor is faulty but not sure where it is or if it can by bypassed? Thanks
Author and @Ifixit open themselves up to law suits and it reflects negatively on many of us for publishing a partial guide such as the above without a proper disclaimer that it is indeed a partial guide. For having 878 points, Author's credibility ought to be docked 75% for posting a guide that misleads people to break their screens by failing to mention the glue and how to deal with it.
*****Please be careful when removing the rear cover. The edge of the screen is very vulnerable and easy to break!!!! *****
Bev - Replica
removing the back can be quite difficult. i found that the tools provided were absolutely useless. A guitar plectrum is much better. be careful on the top edge because the digitiser connector is there and you can easily cut thro it. Apart rom the aforementioned its dead easy.
jim beeby - Replica
I started at the power button. Using a tin metal pry tool you have to push straight down, stop, lever away from the screen a little then push down again until you feel the snap of the back cover come away from the frame. repeat these steps working slow down the tab and along the bottom then up to the top.
vickyjean1007 - Replica
*thin metal pry tool
Bear in mind that the outer edge of the screen rests on a thin ledge of the back cover so you cannot just pry straight down.
