Salta al contenuto principale
Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement, Back Camera: passo 1, immagine 1 di 1
    • Make sure the device is turned off.
    • Using the plastic opening tool, start in the center and wedge the angled tip between the plastic back and the scree.
    • Try to pressure it, wedge it back and forth.
    • Do not wedge the plastic opening tool directly on top of the power buttons and headphone buttons.
  2. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: passo 2, immagine 2 di 2
    • Once the bottom edge has been loosened, use the suction tool to pull it.
    • The second picture shows the internal portion of the tablet once the back cover is removed.
  3. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: passo 3, immagine 2 di 2
    • The first picture shows the location of back camera.
    • Disconnect the rectangular connection from the back camera to the motherboard.
  4. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: passo 4, immagine 2 di 2
    • The picture illustrates what the device should look like once the back camera is removed.
Conclusione
Tingting Liu
Membro da: 09/28/16
25 Reputazione
1 Guida realizzata
USF Tampa, Team 1-4, Cagle Fall 2016 Membro di USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,149
