Introduzione
The battery of the Samsung Galaxy Tab E 8.0 may run out of charge rapidly or may not be able to hold charge at all. This guide will show how to replace the tablet's battery, which is attached to the front panel.
Cosa ti serve
Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
Altre 4 persone hanno completato questa guida.
5 Commenti
Any chance that the tablet will not charge even with a new battery?
Check to see if the ZIF connector is all the way in.
All you really need to do is take out the cable that runs over the battery. After that just disconnect the battery from the logic board and you can remove the battery with the tabs. A lot less steps and less steps that could go wrong.
Can confirm, completed the guide and skipped a total of four steps.
Pospesel -
Note the T378 version has adhesive around the frame. It will need to be softened with some heat, first, but otherwise opens the same exact way. I wasn’t aware of this an accidentally cracked the digitizer lol. Thankfully, I had a spare.
