Salta al contenuto principale
Samsung Galaxy Tab A 9.7 Speakers Replacement
Cosa ti serve
  1. Samsung Galaxy Tab A 9.7 Speakers Replacement, Back Cover: passo 1, immagine 1 di 1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: passo 2, immagine 1 di 2 Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: passo 2, immagine 2 di 2
    • Remove the two 2.8 mm Phillips #000 screws from the speakers.
  3. Samsung Galaxy Tab A 9.7 Speakers Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Heavy-Duty Spudger
    • Each speaker is now only connected to the main device by small plastic snaps.
    • Pry the speakers from the device at these two points using the heavy duty spudger.
Conclusione
Cal Poly, Team S1-G3, Livingston Spring 2017 Membro di Cal Poly, Team S1-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S1G3
1 Membro
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,687
